carb assembly help
i am putting a jet kit on my raptor but i think I lost something, maybe a tube of some sort connecting the two carbs on the exit side????? and I also have a spring that im not sure where it goes????? anyone a blown up view of the carb?
carb assembly help
found the tube still have the spring
carb assembly help
If the spring is about 3 inches long, it belongs between the jet needle holder and the vacuum chamber cover, which is the black plastic cap on top of the carb held on by 4 screws.
If it's very small, about 1/2 long, it belongs between the jet needle holder and the clip and spacer, which rests on the upper portion of the needle. |
carb assembly help
i managed to put it all back together but now i need to adjust the fuel/air mixture but Im not sure which screw that is, I hope im not the only one who tried this without the service manual
carb assembly help
The mix screws are in the center of the carb on the bottom on the engine side.
carb assembly help
And don't screw them in to tight when your adjusting them the tips can break off real easy.
carb assembly help
on the lids that you remove to replace the jets????? my neighbor said that was a drain incase you flood. Im new to all this, I hope I get it right
carb assembly help
ok i got it thx
