Z71 4" lift kit
Old Jul 26, 2003 | 02:24 PM
AustinONeal's Avatar
Default Z71 4" lift kit
I know this is not the right place to ask but i have seen a lot of people with jeeps and trucks in their info section.
I was wanting to get a 4" lift for my z71 could anyone help me out on the cost of one and where to get one?
thanks
Old Jul 26, 2003 | 02:30 PM
hwyTOhell1988's Avatar
www.superlift.com
www.skyjacker.com
Old Jul 26, 2003 | 03:29 PM
Diablo's Avatar
SkyJacker is all I've used so far, and have had no problems. Just do a search for area shops that do lifts and they will hook you up, unless you wanted to do it yourself. Another way would be to find any local truck club that you can join, usually they're willing to help each other out, and are pretty knowledgeable. I'm not sure if the Skyjacker site will give you prices, but can probably give you #'s for local dealers. Good Luck.
Old Jul 26, 2003 | 03:54 PM
Ds650RaCeR's Avatar
www.summitracing.com
rancho 4 in $1,355.95
superlift 6 inch lift $1,299.95
pro comp 4 in $1,295.95
fabtech 6 in $1,412.95
skyjacker 4 in $709.95
skyjacker 6 in $1,199.95
then you got your body lifts and so forth
Old Jul 26, 2003 | 04:22 PM
thunderalley400ex's Avatar
I was wanting to get a 6in lift for my z71 what is better rancho or skyjacker, I have a truck with Rancho and its a good lift just wonmdering if skyjacker is as good????
Old Jul 26, 2003 | 05:33 PM
Diablo's Avatar
I use SkyJacker, so I'm biased. They are both good lift makers, and most of the time Rancho is cheaper. I know that IFS trucks usually cost more to lift, so be prepared.
Old Jul 26, 2003 | 06:12 PM
sixsixT's Avatar
Yeah over 3 or 4 inches and you need to drop the diff. down.
Old Jul 26, 2003 | 09:31 PM
PatsRaptor's Avatar
I have the Rancho 4 on mine and love it its a little tweaked to a 5.5. I have 33s but can fit 35s Never get a body lift you will start over heating do to moving your fan higher then your radiator. if I wasn't able to get the Rancho I would have got the Pro Comp 6
Pat
Old Jul 27, 2003 | 02:24 AM
Diablo's Avatar
My 80 Cherokee has a 4 inch suspension, 3 inch body lift. I took off the fan and installed an electric fan thats controlled by an adjustable thermostat. that fixed the overheating issue. Theres many issues you might run into when getting a lift put on- brake lines, fuel lines, bumper gap, etc. etc. theres remedies for it all, and its worth it in the end.
Old Jul 27, 2003 | 02:26 AM
Mike330R's Avatar
Try http://www.racecardynamics.com/
Looked like the best kit to me.
