raptor still stumbling
Old Jul 26, 2003 | 09:13 PM
ikswodolg's Avatar
Default raptor still stumbling
I had put in a dynojet jet kit along with a K&N high flow air filter and pro design base plate, running stock exhaust and airbox lid, I have a stumble when I jab the gas most noticibale in 1st gear, after the slight stumble it runs strong to redline, if I gradualy feed it thottle its ok, the float level is good, I tried diffrent needle positions, and played with mixture screws some, since its right off idle speed it stumbles, but nothing seems to fix it, needle is on groove 4 on 3 it's doing the same thing but has less overall power and on groove 5 it runs bad thougout. any more suggestions appritated
Old Jul 26, 2003 | 09:25 PM
PatsRaptor's Avatar
You need to adjust your A/F screws out! Go 1/4 turns at a time. You should be able to free rap perfectly with no stumble or back fire.
Pat
Old Jul 26, 2003 | 10:03 PM
ikswodolg's Avatar
it does seem to free rev good, neutral or clutch in, what I meant by speeds just off idle was as slow as you can go in 1st without it stalling or jerking, just kinda idleing along, then when I mash the gas theres a slight stumble before its gets going strong, sorry for the wording, thanks for responding
Old Jul 26, 2003 | 10:11 PM
FireFly's Avatar
lean out the pilot jet
Old Jul 26, 2003 | 11:09 PM
ikswodolg's Avatar
stock pilot is in it now, any suggestions as to what number to start at, thanks
Old Jul 26, 2003 | 11:22 PM
Warrior453's Avatar
umm like 180
Old Jul 28, 2003 | 12:52 AM
FireFly's Avatar
lol thats hilarious
the stock pilot is 22.5 you just need the next step down.
Old Jul 28, 2003 | 01:02 AM
sixsixT's Avatar
Do what pat said sounds a hair lean on the idle mix but carbs with vacuum slides and no accel. pump are prone to have a little hessitation.
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
