what kind of lube should I use for the a-arm lube locations?
Old Jul 30, 2003 | 02:29 PM
roosthrower's Avatar
Default what kind of lube should I use for the a-arm lube locations?
on my blaster. there is only 4 spots to lube right?
Old Jul 30, 2003 | 04:02 PM
will 10/w-30 motor oil work?
Old Jul 30, 2003 | 04:05 PM
HoundDog06's Avatar
I don't know about how many grease certs there are but on the type of grease, I like to use Mystic Marine Wheel Bearing Grease. Its a lithium based grease which wont wash out if you get in water. You can find it at any Mystic dealer.
~HoundDog
Old Jul 30, 2003 | 04:17 PM
thanks
Old Jul 30, 2003 | 04:19 PM
HoundDog06's Avatar
If you have the manual to your blaster there should be a section in the lubrication section that addresses where to grease.
~HoundDog
Old Jul 30, 2003 | 04:21 PM
warrior007's Avatar
I also use a marine grade wheel bearing grease, There are 6 zerk grease fittings on the a-arms of a blaster not sure about the back
Old Jul 30, 2003 | 04:26 PM
Raptorx44's Avatar
Lithium Soap Based Grease
Old Jul 30, 2003 | 04:41 PM
Raptorx44's Avatar
Hey Warrior007 i sent you a PM.
EIF
Apr 20, 2017 07:15 PM
Oct 10, 2015 10:20 AM
Lucas Bohanan
Sep 29, 2015 01:16 AM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
bmark0610
Sep 7, 2015 09:42 PM
