warrior screw on carb
Old Aug 15, 2003 | 12:21 AM
OneWheelWheelie's Avatar
Default warrior screw on carb
how do i know my screw is just perfect for my idling and not running to rich or no t enoguh how do i make sure it is pefect bike is yamaha warrior 99
Old Aug 15, 2003 | 12:23 AM
KILLERCUDA's Avatar
well if u stand on it and it bogs yer runnin rich and if it just climbs in rpms comes back down and dies or wants to you are lean. You are talking about the air screw right?
Old Aug 15, 2003 | 12:26 AM
the scre on the carb that you can screw in or out should my bike be able to go forwar idling in first or not i know it does it in reverse but should it do it in first or is iturnes in or out too much
Old Aug 15, 2003 | 12:39 AM
Crotts's Avatar
It will move forward with out you giving it any gas, if that is what you mean. I'm not sure the correct way to set you idle, I just set it so it doesn't sound like it is idling real high
Old Aug 15, 2003 | 12:49 AM
ok
Old Aug 15, 2003 | 12:50 AM
thanks
Old Aug 15, 2003 | 12:53 AM
i have the same bike as you same colour and everything how fast does it go with all the accesories i would like to know
Old Aug 15, 2003 | 12:57 AM
KILLERCUDA's Avatar
Cool, With my mods I would say close to 70 maybe more. I geared up to a 14 tooth for my 20 inch tires so....It can go more than it does now ehhehehe
Old Aug 15, 2003 | 01:22 AM
Crotts's Avatar
I'm not sure how fast, couldn't even guess. I have 22" on the back and the stock gearing and mine kills my buddies stock warrior
Old Aug 15, 2003 | 01:29 AM
KILLERCUDA's Avatar
Can I take that as a compliment Crotts? hehehe
