is cluching a warrior hard to do ?
Old Aug 15, 2003 | 11:26 PM
TrailBlazerguy250's Avatar
Default is cluching a warrior hard to do ?
i had a blaster and couldent drive it. just taking off is the problem. i can shift fine
Old Aug 15, 2003 | 11:30 PM
JakalWarrior's Avatar
They are all the same, its a learned skill. A warrior is a touch easier though because of the low first gear and good bit of torque. If you cant get started on a blaster though dont expect to jump on a warrior and be a pro. Its not that much different.
Old Aug 15, 2003 | 11:31 PM
Yamaha4eva's Avatar
if you are afraid of clutching, you should slap yourself, its the easiet thing to do and its alot better then automatic
Old Aug 15, 2003 | 11:38 PM
iam not a afaid of cluching i do a lot of long trips and was wondering if it was easier to cluch than a blaster. dont reply if your not gonna help
Old Aug 15, 2003 | 11:40 PM
the warrior looks identical to Jackelwarrior's warrior but it has lights. but same colors. but this has a blue seat
Old Aug 16, 2003 | 12:02 AM
RaceWarrior350's Avatar
Like jackal said, Clutching is a learned skill and it may be a little easier on a warrior but it still is just about like a blaster, once you learn it, you wonder why you thought it was so hard.......
Its so easy,
1.pull in clutch
2.Shift into first
3.give some throttle while slowly releasing the clutch
doesnt get much simpler, thats just a good way to learn, you will do it differenty when you start to get a good feel for it.......
Old Aug 16, 2003 | 12:10 AM
ok thanx i tried over 100 times a day w/ my blaster and couldnt get it to move. i think i waant giving it enough gas?
Old Aug 16, 2003 | 12:11 AM
did it stall out when u let off the clutch?
Old Aug 16, 2003 | 12:12 AM
but then i found out that the cranck case was rusted and then they had to put a new crankcase in it. would that have any thing to do w/ me not being able to get it going ?
Old Aug 16, 2003 | 12:15 AM
umm the crankcase on the blaster is aluminum and aluminum doesnt rust, did you even get this thing to start and run?
