raptor carbs!
Old Aug 26, 2003 | 05:02 PM
KFX700Kid37's Avatar
Default raptor carbs!
my friend has a 01 raptor and we were riden last night and it just staled. it was dark so we just pulled it home and didnt look at it. today we saw that the carbs were off. this is not the first time it has happend and it sucks. does anyone know how to make it so the carbs dont come off when ever they want to?
thanks
Old Aug 26, 2003 | 05:07 PM
WallStreet's Avatar
Mine was doing this, also. My intake valves were too tight, so make sure and adjust them. I also bought UPP intake manifolds for $100. THEY ARE GREAT! Sometimes I can hear it backfire and they always hold. Get them and the problem will stop, I guarantee it.
Old Aug 26, 2003 | 05:08 PM
HoundDog06's Avatar
Have you checked your valves in a while? How about your jetting? The two main problems resulting in blowing off of the stock carbs are either a lean backfire, or more often it seems the valves are out of adjustment. The intake valves on the raptor like to tighten up and allow combustion to blow past the valves into the intake boot. Try these two and see if it helps. With everything in adjustment, you should have no problems keeping the carbs in the stock boots. Don't just go out and get an aftermarket set of boots. If it is backfiring, you have a problem that needs to be fixed before it causes further damage.
Let us know how it goes.
~ HoundDog
Old Aug 26, 2003 | 05:13 PM
thanks my friends happy now... well take it to his uncles shop tomarrow to get that fixed
WallStreet's Avatar
True, I forgot to mention the lean issue. I was trying to say to try the cheaper alternatives first. But he may have been confused, or wasting money. Nothing wrong with a little constructive criticism!
Old Aug 26, 2003 | 06:01 PM
sixsixT's Avatar
It helps to idle it a little high.
Old Oct 22, 2003 | 06:02 AM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
mine blew off
I richened the bottom end, and set the idle a little higher (based on other peoples advice from here)
used a better set of hose clamps (not too tight)
no problems in a year
no stalling either (which can also damage your one-way gear)
Firefighter400
Oct 8, 2022 06:38 PM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
black_thunder
Jul 9, 2015 05:58 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
