Yamaha warrior help!!!!!!!!!!!!!!!
Old Aug 29, 2003 | 08:22 PM
sickness89938's Avatar
Default Yamaha warrior help!!!!!!!!!!!!!!!
hi everyone......i have a 92 warrior and it wont start it only does when you bump start it........it turns over wen you press the start buttom it turns over very slowly i just bought a new starter and put it in but it didnt help[img]i/expressions/face-icon-small-mad.gif[/img] i was wondering if you have any idea why its not turning over correct........thanks
Old Aug 29, 2003 | 08:48 PM
Crotts's Avatar
Check the voltage of your battery, you may need a new one
Old Aug 29, 2003 | 08:57 PM
i did that and i just got one not to long ago........idk wats wrong wit it its pissin me off lol
Old Aug 29, 2003 | 10:54 PM
OneWheelWheelie's Avatar
Guys something happend to me like that on my 99 warrior but it made noise when it rolled over and it also rolled over their is this thing called a starter clutch inside somewhere around the starter mine was seized check that and i bet ya it's the problem
Old Aug 30, 2003 | 12:43 PM
RaceWarrior350's Avatar
Yeah i had to replace the starter clutch on the inside of my flywheel, That could be your problem which if u replaced the battery, checked all connections, and starter that has to be the problem, remember the allen head bolts on the flywheel are counter sunk and you cant take them loose while they are on the bike, you have to pull the flywheel first.......
Old Aug 30, 2003 | 12:56 PM
WolverineMan15666's Avatar
Check the stator. Not the starter, the stator. A buddy had the same problem. It was the stator.
2quiker
Mar 22, 2022 08:36 PM
Sep 17, 2015 03:06 AM
Yamaha Side by Sides
Sep 8, 2015 01:43 PM
