raptor 80 lights (help)
Old Aug 30, 2003 | 11:36 PM
zquader's Avatar
Default raptor 80 lights (help)
hey guys my son has a raptor 80 and i want to hook him up with some light can you help
Old Aug 31, 2003 | 12:51 AM
TheAvenger's Avatar
I don't think there is a kit out there like for the LT80, but it shouldn't be a problem. If there is any problem, it would be where to mount the lights. Do the fake lights come off? If so, you might could mount some small lights (about the size of the fake ones) there.
But wiring it up will be simple. Just run the positive wires of the lights to a on/off toggle switch and from there to the positive terminal on the battery then ground the negative wires to the frame somewhere.
I'd use 55 watt or less lights since the battery is small. Oh, and I'd use an inline fuse with the positive wire. You should find everything you need (wire, terminals, switch, lights) at any automotive store. You could drill a hole somewhere in the plastic to mount the switch. Just make sure it's always turned off when the 'wheeler isn't running! [img]i/expressions/face-icon-small-smile.gif[/img]
(you could also just use one light, mount it to the bumper or handle bars, and all this applies to a tail light too.)
Aug 21, 2015 01:23 PM
HYS
Aug 18, 2015 12:28 PM
GNorm
Aug 1, 2015 11:06 AM
black_thunder
Jul 22, 2015 06:01 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
