YFZ450 Jetting ?
Old Aug 31, 2003 | 02:01 PM
TRLYFZ450's Avatar
Default YFZ450 Jetting ?
I have the air box cover removed peashooter out and have done the cam mod. What should my jetting be.
I have a 175 main 5th clip on needle and a 45 pilot jet. Elevation is 500 feet. Thanks
Old Aug 31, 2003 | 08:35 PM
amsoil123's Avatar
Your stock needle will make you run lean......source:Sparks racing.For now use a 180 main.You need the needle from a 2003or4 yz450f,then change the main to a 170.Hope this helps.
Old Aug 31, 2003 | 09:11 PM
FX1660R's Avatar
did mine on dyno with same mod of you
best result was with:
#170
pilot#45
no lid
cammod
needle#5
mixt 2¼
peashooter in trashcan
elev 800'feets
i think your rich a little
MY DYNO
Old Aug 31, 2003 | 09:18 PM
TRLYFZ450's Avatar
Thanks
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
Sep 23, 2015 06:23 AM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
