Jetting with new pipe
Old Jun 2, 2000 | 01:08 PM
clc900's Avatar
I have a '99 Banshee and just installed pro-circuit pipe/silencers, boost bottle, reeds, reed spacer, pro flow filter, and 270 jets. Runs fine but one question. When I have it pegged going down a dirt road, maybe 3/4 throttle in 6th I hit the throttle the last 1/4 and the power stays the same (no increae) but I hear a deeper tone coming from the airbox. Is this normal? It doesn't bog down but I get no additional power going from 3/4 throttle to full throttle. Any suggestions?
Chad
Old Jun 6, 2000 | 10:24 AM
clc900's Avatar
I am thinking I should go to a bigger main jet. What does everyone else think? I don't know a whole lot about pilot jets and needles. Any suggestions?
Chad
Old Jun 6, 2000 | 06:14 PM
morvac's Avatar
run it down that road again wide open then kill it roll to a stop and take a plug reading. Thats about the best way to tell. 270 isn't a bad place to start....i was running 280s with those pipes.
Old Jun 6, 2000 | 06:34 PM
clc900's Avatar
Does yours pull all the way through to open throttle? Have you done anything with the needles or pilot jets?
Chad
Old Jun 7, 2000 | 12:19 PM
morvac's Avatar
yeah...mine revs out fine when going flat out... had a little stutter around 1/4 open, but changed needle position and fixed that. Nice and smooth all the way up now...with harder pull in mid to top. Check the plugs after you go wide open for a bit and that will tell if your close...if so, then might not be jetting. Are you running with airbox lid off or on?
Old Jun 8, 2000 | 11:23 AM
clc900's Avatar
I run with the air box lid off with an outerware on the pro flow filter. What jets are you using?
Chad
ReconBayou
Oct 31, 2022 05:37 PM
mrtidy
Feb 3, 2016 05:00 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Brandon400
Sep 5, 2015 08:44 PM
