Connecting rod
Old Sep 22, 2003 | 03:47 PM
yamamayzf1000r's Avatar
Default Connecting rod
Guys,
What is the weight of the stock rod vs. the aftermarket carillo rod?
Old Sep 23, 2003 | 11:11 AM
Someone out there must know the answer to this question.
Old Sep 23, 2003 | 09:45 PM
bumpity bump
Old Sep 23, 2003 | 10:04 PM
sixsixT's Avatar
Here ya go.
Here are the rod weights. Gram for Gram Titanium is 4 times stronger than steel. Hope this helps. Zombie
Ti 254.3
Stock 350.0
Carillo 445.3
Old Sep 23, 2003 | 10:34 PM
BadNBlueRacer05's Avatar
probably 4 times as expensive too...
Old Sep 23, 2003 | 11:58 PM
desracers's Avatar
It only 500 dollar for the Ti- rod...... It only money....
Old Sep 24, 2003 | 12:04 AM
Chimmer's Avatar
Somebody has to ask: who makes the ti rod & who sells em......
oh ya, who runs 12:1 or higher with stock rod, hope Im not stealing your post?
Old Sep 24, 2003 | 12:41 AM
sixsixT's Avatar
Make- Carillo I think
Sell- Craycraft
There's alot of 12:1 stock rod engines out there, most of the Texans run that set up.
Old Sep 24, 2003 | 01:42 AM
Mr45auto's Avatar
I'm running a 12:1 686 with the stock rod, stock '01 trans, and clutch basket. So far so good. If it holds together till March I'll upgrade with the '02 trans and carrillo rod. I'll probably have it lightened.
Old Sep 24, 2003 | 06:21 PM
Chimmer's Avatar
Mr45auto, thanks for the reply, glad your riding on the edge, just don't fall off, LOL...
Most engine builders told me even the 11:1 piston I am using is stressing the stock rod too much. I will try the 12:1 stock or slight overbore piston with a ported/polished head & maybe selected bigger valves & see how she holds up. If it makes it thru the year I will tear into the bottom & replace the '01 tranny & stock rod as well. Sounds like the Texan crowd likes that setup, aluminum piston/stock rod revs faster, so I hear....
By the way, are you talking about having the Carillo rod lightened? How about spending the extra cash for the ti rod?
