please help
Old Jun 5, 2000 | 08:21 PM
kmoney's Avatar
I have a 99 warrior with a DG pipe and a KN air filter. I was thinking about changing the sprockets but don't know anything about what size to get. I want it to have better low and mid range power without losing much top end. Can anyone please help?
Old Jun 6, 2000 | 02:25 AM
hot_shoe_cv's Avatar
Assuming you're running the stock sized tires, the inexpensive way would be to drop one tooth on the c/s sprocket to a 12T. This will give you more low & mid range but at the expense of top end. The other way to shorten the gearing would be to buy another rear sprocket a couple of teeth larger.
