Recommend new pipe for Raptor?
#23
Do you guys have just the slip-on, or the full exhasut? Does the header pipe really make much of a difference? Also what other mods did you do along with your exhaust? Jetting, intake, etc...? Are all jets kits the same, or would you guys recomend one over the other? What are some good intakes that you would recomend? Sorry for all the questions, but I didn't feel like starting a new thread for each one, and yes I am using the search feature, so I am gathering info that way as well.
Thanks in advance for any and all info.
2-Knee
2-Knee
#24
Just curious,why does most people have Yoshi?Is it the sound,hp,looks,or all the above.I'm thinking of going with the Alba because most people say any pipe you go with you'll be satisfied and Alba is the cheapest.
Thanks,
James
Thanks,
James
#25
Something you might want to think about is, Where you are going to be riding. Some areas have dsbl. restrictions. That's why I went with a BIG GUN you cnan change the packing for your riding area. The guys at BIG GUN are great to work with if you should need anything or have a problem.
#26
Albas deal is hard to beat. Their pipes are as good as any and produce as good of power as any imo.
#27
The Albas pretty good, wshrdskins runs real good with that pipe. I went with the Yosh because I don't care for disc type mufflers, fit & finish are nice, all SS, uses the stock heat shields, sounds good, you can add the TEC insert if you need to quiet it down and from want everyone says and the dyno info I've seen it has a real smooth power curve from bottom to top. But most importantly I think it looks good [img]i/expressions/face-icon-small-smile.gif[/img] and the local shop was having a 20 percent off sale when I went in to buy some oil.
As far as intakes go I think my adapter is the best bar none for dessert and dunes, But I may be a little bias.
[img]i/expressions/face-icon-small-wink.gif[/img]
#28
LOUD IS GOOD But not at Glamis this year. BIG GUN has a quiet pack for there silencer and I don't know about you but I like to wear shorts when I ride. With the ceramic coating on the head pipe I feal no heat! [img]i/expressions/face-icon-small-cool.gif[/img]
#29
How much is the Yoshi pipe??
I probably won't be riding in any areas where dbs are an issue.Does the Albe come with a spark arrester?f not what are my chances of burning the woods down?
And do I need a filter kit to actually feel the most of this power?If so than the Alba s probably my best shot.
Thanks again,
James
Thanks again,
James
