ign. timing vs starting
Old Sep 30, 2003 | 08:42 PM
Ward660R's Avatar
Default ign. timing vs starting
Am I correct in thinking an advanced ign timing will be harder to start? This is on methanol if it matters.
I have my flywheel off right now. I am thinking about trying an advanced key for it, just to see. BUUUuuut if it is going to be much harder to start there is alomst no point.
TIA!!!
[img]i/expressions/face-icon-small-cool.gif[/img]
Old Sep 30, 2003 | 08:51 PM
FireFly's Avatar
I don't know about methanol but I was told not to use an advance key while running high compression it causes detonation
Old Sep 30, 2003 | 09:39 PM
ShadyRascal's Avatar
You are correct, advancing the ignition will make it harder to turn over and start. Builds more cylinder pressure before TDC.
Old Oct 1, 2003 | 05:50 AM
Ward660R's Avatar
Thanks for confirmming Shady.
FireFly, true it can. BUT methanol likes to have the igntion advanced some, power wise anyway, and it also combats the detonation problems.
I guess I am going to have to get a DYNA or Vortex ign. and either find a curve with low or no advance under 1,500 rpm, or program one to do that.
Anybody have any lucky lotto numbers they want to share???[img]i/expressions/face-icon-small-wink.gif[/img]
MikeyBoyesq
Nov 27, 2020 02:44 PM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
dnm48
Jun 14, 2015 10:11 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
