Raptor lights
Old Oct 2, 2003 | 07:12 PM
RaptorOwner's Avatar
Default Raptor lights
Sam, did those come with the connectors that plug in the stock harness?
Old Oct 2, 2003 | 07:58 PM
BUDXXX's Avatar
Mine came with some connectors, but not anything that would plug into stock harness.
I had to cut the low beam wire to each stock light, and redirect that circuit thru the trailtechs, which allowed me to use the trailtechs with the stock light hi/lo selector switch.
Old Oct 2, 2003 | 09:34 PM
How is your battery holding up? Sounds like it looks pretty sweet at night. I sure do like night riding in the dunes. Especially if you have a group with you and your just playing follow the leader.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Oct 3, 2003 | 12:08 AM
Starky's Avatar
Can the stock stator handle the stock lights as well as the Trail Techs or do you need a heavy duty one to run both.
Old Oct 3, 2003 | 06:03 AM
  #15
Ward660R's Avatar
It will run both with the 35watt TrailTechs, I am sure of this.
I think somebody runs 2, 50 watters and the stock lights as well, but I am not sure about that.
Old Oct 3, 2003 | 10:53 AM
  #16
HappaRap's Avatar
Lazy Boy Rider!
Is there any difference with the size of wire used with the Trail Tech between 35watt and 75watt, or is the only difference the bulb?
Old Oct 3, 2003 | 12:53 PM
  #17
Thor2's Avatar
The only difference between the 35 watt and 50 watt trail tech lights is the bulb. They use the same wires. trail tech has a new stock position raptor light. The new lights have vibration isolated mounts.
Aug 21, 2015 01:23 PM
HYS
Aug 18, 2015 12:28 PM
GNorm
Aug 1, 2015 11:06 AM
black_thunder
Jul 22, 2015 06:01 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
