need help on which atv to get
Old Oct 7, 2003 | 03:32 PM
BlasterBo827's Avatar
Default need help on which atv to get
Hey yall im 14 and im tryin to decide wat atv i should get... i want one dats fast but ima start hunting next year and i got a budget... its between the Ozark 250 or the Yamaha Blaster... which one is less maintannece and which one would be a better over all atv for me... thanx pleez respond A.S.A
Old Oct 7, 2003 | 04:29 PM
pleez yall i really need help on which one to decide
Old Oct 7, 2003 | 04:33 PM
BornToRide101's Avatar
I never heard of an Ozark but i would go with the blaster, i havent heared aney bad things about them and yamaha has a good rep. Whut is your budget?? it would be better to buy a second hand warrior than a new blaster.
Old Oct 7, 2003 | 05:56 PM
yfzblaster1's Avatar
i would go with the blaster. they last long time and should be good for your size(guesing)
never heard of the ozark?
Old Oct 7, 2003 | 10:20 PM
roosthrower's Avatar
if you ride alot of mud the ozark would be best. if you want to have a four wheeler that you can mod and be faster than your friends get the blaster.
Old Oct 7, 2003 | 10:27 PM
Raptorkid25's Avatar
Ozark and Blaster r to completely different fourwheelers..If u are gonna use it for hunting go w/the Ozark it is more of a utility fourwheeler
Old Oct 8, 2003 | 02:48 AM
Kraw's Avatar
blaster wouldn't make a good hunting bike
Old Oct 8, 2003 | 09:26 AM
Raptor149's Avatar
The Ozark would definitely be less maintenance. You don't have to rebuild the engine as often(4 stroke), you don't have to change plugs or clean the filter as often, there probably is no clutch, and I think it's shaft drive, which means no chain adjustment. But it all depends on what type of riding you want to do.
Old Oct 8, 2003 | 01:22 PM
thomez's Avatar
It's hard to hunt with a 2-stroke around and you sure couldn't use that Blaster to haul much. The Ozark is more of a bike than most give it credit for, a buddy of mine has one and loves it. Climbs well, moves pretty good, and will do you best for both fun and hunting. No decision here - Ozark all the way.
Old Oct 8, 2003 | 07:04 PM
Eceriderjbomb's Avatar
im with thomez zark is the way to be
