YFZ 450 toe in problem/question
Old Oct 11, 2003 | 11:59 PM
DietCokeOfEvil's Avatar
Default YFZ 450 toe in problem/question
After a day of hard trail riding and a few hard hits on small trees that lined the trails with my tires and a-arms, my toe in was pretty out of wack. I just got through adjusting the tie rods and with the handle bars straight and the wheels aligned using just the tie rod adjustment, I noticed that I may have a problem with my steering stem. I can turn the handle bars noticeably further to the left than I can to the right. This obviously could make some tight right hand turns problematic... anyone have any suggestions? One other thing... there is alot more thread showing on both the tie rod ends of the right tie rod than the left. There isn't much thread showing on either end of the left tie rod. Think this is just a bent tie rod?
MiZZiE
Dec 13, 2009 12:37 AM
