jets 165/170 too much for my raptor?
Old Oct 23, 2003 | 02:50 AM
AustinONeal's Avatar
Default jets 165/170 too much for my raptor?
just wondering if i take the lid off and had these jets with a #25 pilot jet then it might run better
heres how im seeing it i take the lid off i lose the midrange power well then its too much air not enough gas
well put 165\170
and then when i take the lid off ill have enough gas for the air im getting
maybe?
Old Oct 23, 2003 | 08:55 AM
garyc660R's Avatar
Maybe....maybe not. No-one can tell you exactly what your Raptor needs for jetting. I ran 148/150 with no lid and an aftermarket exhaust using 27.5 pilots. The only problem I had was the need too lean the DJ needles one notch because of the increased turbulence from no lid. Start high on the jetting and keep an eye on the plug.
Old Oct 23, 2003 | 01:20 PM
raptor03's Avatar
either that or 160/165 was what i used at 3,000 feet to 5,000 feet, with a 25 pilot jet and no lid..
Old Oct 23, 2003 | 08:27 PM
sixsixT's Avatar
What kind of needles and jets DJ or Mikuni?
Old Oct 23, 2003 | 10:15 PM
im running mikuni jets
Old Oct 23, 2003 | 11:36 PM
sixsixT's Avatar
What needle? The jetting in your sig would be for a DJ kit. If you using DJ needles (which most say not to use with Mikuni mains) I would try 160/165.
Old Oct 24, 2003 | 12:30 AM
ok should put the stock needle back in?
Old Oct 24, 2003 | 01:23 AM
sixsixT's Avatar
You could try it with the DJ needles but you'll probably have a low end stumble that will be hard or impossible to get rid of and if they don't work put in the stock ones.
Old Oct 24, 2003 | 08:12 AM
garyc660R's Avatar
I am currently running DJ needles and Mikuni mains.....adjusted correctly I like the set-up.
bmxatv10
Oct 14, 2022 06:23 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
