wolverine help
Old Jun 16, 2000 | 10:44 AM
yamahon's Avatar
i took my wolverine to the shop to get things fixed that i thought was the only thing wrong with it and the guy told me that the 2 front axles need to be replaced and the bearings and seals in the front and rear and the u joints
my questinon is:
were is the cheapest place on the net were i can get 2 front axles cause he said they would run at $350-$400 but i know i can get them cheaper?
were is the cheapest place were i can get front ujoints?
Old Jun 16, 2000 | 01:54 PM
gregsims's Avatar
What exactly did he say was wrong with your front axels? The rear drive shaft u-joint very rarely goes out on wolverings unless you have a lift on it or a torn boot. The front drive shaft u-joint is not usually a problem either. If you haven't broken a front cv, I'm curious what the problem is that can be fixed, unless you have been running the atv on bad bearings for a extremely long time. If you have a broken CV, usually only one will break at a time, because when one breaks, it relieves the pressure off the other ones. You can buy bearings yourself at any bearing specialty shop cheap, and probably seals to. Your stock bearings were not sealed bearings. Make sure the new ones are. I will check back for your answer later.
Greg
suzuki230
Jul 8, 2016 10:03 AM
Nelson
Jun 22, 2015 03:51 AM
Nelson
Jun 20, 2015 01:59 PM
ragewraps
May 27, 2015 08:07 AM
holmbergm97
May 27, 2015 07:23 AM
