Vp red or Ultimate -4 for a 12:1 686 raptor?
Old Nov 17, 2003 | 01:29 PM
POLARISFREAK's Avatar
Default Vp red or Ultimate -4 for a 12:1 686 raptor?
I know mine is a two stroke, but I've run av gas for over a year with no problems and can't tell a performance difference. A lot of people don't like it, but I can get it for less than 2bucks a gallon and it readily availabe. I will be doing some drags tests with it at the track next year to see #'s on if there is a performance difference between it and race gas.
Old Nov 17, 2003 | 02:23 PM
Ernie660R's Avatar
Ultimate-4, all the way. Even on two-strokes!!!
Old Nov 17, 2003 | 02:27 PM
How much is that stuff per gallon, in the long run wouldn't you be better off going to methanol?
Old Nov 17, 2003 | 09:43 PM
wshrdskin's Avatar
Originally posted by: raptor03
yea they have av gas up in palmdale near me at the airport..,i may have to try that..I e-mailed the VP re and he reccomended the MRX-01 straight and that is a 98 octane,and he also told me i could mix ultimate-4 and som c-12 50/50 for a good mix
Sam, I checked into MRX01 a while back. It's $79 for 5 gallons then. I'd be scared to see what it costs now. It's also only 2.55% oxygentated. The Ultimate 4 is 6% oxygenated.
Old Nov 17, 2003 | 09:55 PM
  #15
raptor03's Avatar
dave i found a station right by the house that sells 100 and 110 ,the station you had mentioned,are you running the 100 straight ..
Would the 100 plus a little of the 110 bring up the octane level or is that all wrong ..?
Old Nov 18, 2003 | 03:06 AM
  #16
jcdraptor's Avatar
I'm curious what I should be using. I didn't bore it, just have a 13:1 high compression piston, port and polish, and a stage 2.
Old Nov 18, 2003 | 10:29 PM
  #17
wshrdskin's Avatar
In theory mixing 50/50 with 100 and the 110 will give you 105 octane. 76 somtimes has a mixing chart they'll give you. Yes I am useing the 100 strait.
Old Nov 18, 2003 | 10:32 PM
  #18
wshrdskin's Avatar
JCD, I would run 105 octane or more, jmo.
bmxatv10
Oct 14, 2022 06:23 PM
Sep 30, 2015 01:37 AM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
