raptor idles up?
Old Nov 16, 2003 | 11:52 PM
NY02Raptor's Avatar
Default raptor idles up?
ok all i have a 2002 raptor with the foam replacment air filter (double foam) it has a dg extreem stage 3 pipe i believe thats all thats done motor wise.. right now im back on stock jets.. even though it says to run 150/155 it runs really rich... so here is my question why when its cold i have to turn the idle screw in then as it warms up i have to keep backing it out... this happens at all temps.. if its 70 out.. i still have to use the choke to start it.. and it wont idle.. turn the idle screw in.. and it idles.. then back it off as it warms up.. i also noticed it does seem to be lean in the idle head pipes glow a bit in the dark if i let it sit and idle for a long period...
Old Nov 17, 2003 | 12:10 AM
Raptor8tor's Avatar
check your carb boots on both sides of the carb.
Old Nov 17, 2003 | 12:35 AM
NY02Raptor's Avatar
both are on... no rips that i know of...
Old Nov 17, 2003 | 07:56 AM
PARADISE's Avatar
NY02
I had the same problem though mine was running lean and I adjusted my valves and the it now idles
and runs strong
regards Rod
Old Nov 17, 2003 | 06:02 PM
NY02Raptor's Avatar
hmm see i dont know if anyone has ever been into the engine.. ill find that out this winter as i intend to tear it down.. polish some stuff.. poweder coat some other stuff.. and so on [img]i/expressions/face-icon-small-smile.gif[/img]
Firefighter400
Oct 8, 2022 06:38 PM
Aug 21, 2015 01:23 PM
black_thunder
Jul 22, 2015 06:01 PM
brad wheeler
Jul 13, 2015 11:19 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
