what does this part in the motor do?!
Old Nov 18, 2003 | 11:39 AM
Ugintel's Avatar
Default what does this part in the motor do?!
ok when i got my bike back from the shop after the near 400 labor bill, it had this ticking noise many people on here have gave me suggestions, well i found waht it is. on the cam theres this little pin that moves in and out with this rod that comes out of the enad that lets the pin drop out with a spring on the bottom of it. what the HELL is that for? the guy put it in baclkwars so it was actually comming up at the WRONG tiem and hitting my rocker arm and it had JUST enough push that it would open my valve. Anyhow when i was racing it floated THAT valve. what do you think i should tell the shop? I paid them $45.00 an hour to work on my bike, i paid that price so it would ALL run right, so you think they are liable?
Thanks!
Old Nov 18, 2003 | 11:49 AM
KGB's Avatar
KGB
Sounds like a decompressor. I would tell him to fix it.
Old Nov 18, 2003 | 11:50 AM
sixsixT's Avatar
That's the deccompression pin. It stays out until the cam is spinning fast enough to move the weights out and retract the pin.
Old Nov 18, 2003 | 11:53 AM
Ugintel's Avatar
so it if was put in backwards it would not operate right and could cause that? i mean it's not suposed to hit the rocker arm every time around no matter the RPM?
Old Nov 18, 2003 | 12:24 PM
MDkodiak450's Avatar
Thanks![/quote]
Your lucky, my local shop charges me $87 an hour! I need to find a new shop. my shop is Ellicott City Motorsports in Ellicott City, MD.
Old Nov 18, 2003 | 01:04 PM
DuneMe's Avatar
And this is reason #1 why I prefer to do my own work.
You are not alone! Many of us have experienced a little lapse in attention to detail from the dealer.
What quad was this on? Doesn't sound like the Raptor the way I am reading it [img]i/expressions/face-icon-small-confused.gif[/img] I can't think of how it can be put together wrong on the Raptor. . .
Yes, they should fix it for free. This was clearly their mess up!
Not knowing the set-up, I would think this could be very dangerous - could potentially open the valve when the piston is up???
Old Nov 18, 2003 | 07:12 PM
Ugintel's Avatar
DuneMe, it was explained to me that on the wheel that the cam is attached to there are the spring thingys that with cintrifical force the spin the rod in the end of the cam 180 deg. and it allows that pin to drop down after it starts. (the pin is a decompresion pin) well the dumb *** put the part that turns 180 Deg. on so that when it hits the right centrifical force it dosen't drop free, it actually pushes it up! i never saw anywhere in the maual where it talked about this. so anyone else that has a rappy be careful to get that right... it does or did open my valve when it was running and when i hit HIGH rpm it broke the valve. sorry if my terms are not right as i am a lamen to this sort of stuff
Waddell4436
1) Engine problems..
Jul 20, 2015 09:46 AM
ghost civic
Jul 19, 2015 10:13 AM
ghost civic
Jul 15, 2015 10:48 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
