Raptor backfires
Old Nov 20, 2003 | 03:10 AM
caliraptor's Avatar
Default Raptor backfires
I hadnt noticed but my quad backfires when I let go of the gas. Im riding around and let go of the gas still in gear and it goes Pop! What does this mean? It keeps popping until the rpms reach an idling level. I can probably get a good 7-10 pops from WOT to a complete stop.
Old Nov 20, 2003 | 04:30 AM
URCRAZY's Avatar
CHECK YOUR INTAKE SYSTEM, AIR FILTER SEAL, BOOT TO CARB SEAL, BOOT TO AIR BOX SEAL. MY BUDDY HAD THIS PROBLEM WITH HIS RAPTOR ALSO, IT WAS THE BOOT TO CARB, LETTING TO MUCH AIR IN.
CHECK IT OUT.
Old Nov 20, 2003 | 04:31 AM
URCRAZY's Avatar
I FORGOT TO ASK, DID IT JUST START HAPPENING, OR DID IT AFTER YOU PUT THE EXHAUST ON. JETTING??
Old Nov 20, 2003 | 09:19 AM
McFly's Avatar
Thats pretty normal on all raptors with aftermarket pipes on. Some are just worse than others.
Old Nov 20, 2003 | 11:33 AM
CaptBags's Avatar
Check that your joint where the slip-on goes onto the header pipe has no leaks! If so put high-temp gasket sealer on it and, re-tighten!
Old Nov 20, 2003 | 10:23 PM
TJw6981's Avatar
Jetted wrong... Check your plugs they are very informative...
Travis
Old Nov 20, 2003 | 10:25 PM
XxDumontRaptorxX's Avatar
When I get up to the top of the dunes at dumont, ussualy revving it high full throttle, on the way back down it pops and stuff. I check the plugs and it looks fine. I think mine likes to backfire after she gets warmed up. I dont know if its bad or not :/
Old Nov 20, 2003 | 11:37 PM
Yamaha660R's Avatar
Mine cracks and pops and stuff as it idles down, but not a backfire.
More of a rumble. Like a Harley. [img]i/expressions/face-icon-small-wink.gif[/img]
Old Nov 20, 2003 | 11:43 PM
PUSHINTHELIMIT's Avatar
Boy.... Lot of Rappy owners not jetted right... Try some richer pilots for cryin out loud.
ReconBayou
Oct 31, 2022 05:37 PM
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 12, 2015 09:39 AM
Brandon400
Sep 7, 2015 12:20 PM
