Raptor steering question.....HELP!!!!!
Old Nov 20, 2003 | 12:03 PM
tuffguy31's Avatar
Default Raptor steering question.....HELP!!!!!
have a problem guys , had a small accident and hit a tree doing about 15mph front bumper took most of the impact , It didn't feel like i hit the tree that hard but the right wheel skimmed the tree also. now i notice that when the handle bars are pointed straight the wheels are turned to the right., when i make the wheels straight the bars are pointed to the left, i checked everything as for any damage and there is nothing visable it is almost like my bars moved somehow could this happen? What could be wrong? is there a way i could straighten the bars? What is under the plastic cap under the handlebars is there a nut under there that could have gotten loose? please help i am sick about this and would rather fix it myself if i can thanks guys.
Old Nov 20, 2003 | 03:18 PM
sandRappy's Avatar
You could just set the handle bars so they are straight, and then adjust the tie rods until the wheels are straight as well.
Old Nov 20, 2003 | 03:35 PM
RacinJason's Avatar
probably the piece that bolts on the bottom of the steering shaft by the bearing...is it bent?
Old Nov 20, 2003 | 05:00 PM
tuffguy31's Avatar
just checked it out i notice when the wheels are pointing straight that the piece on the bottom that bolts to the steering stem is also straight, but when i point the handle bars straight the piece along with the wheels point to the right, could it be the steering stem?
bmxatv10
Oct 14, 2022 06:23 PM
Sep 30, 2015 01:37 AM
35dodge
Sep 29, 2015 09:40 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
black_thunder
Sep 22, 2015 07:59 PM
