CAN ANYONE HELP ME!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Nov 26, 2003 | 11:10 PM
snysny's Avatar
Default CAN ANYONE HELP ME!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I just put my ct full system on and jetted the carb 170/175 it has a k&n filter no lid on air box. I took it for a test ride and at the top of the gears it has a hesitation should i go to 165/170 the ct company says the 170/175 works but i live in fort scott kansas i have no idea what to do. CAN ANYONE HELP ME!!!!!!!!!!!!!!! and will it hurt the engine to run it rich. Does anyone else have this set up.
Old Nov 26, 2003 | 11:19 PM
sixsixT's Avatar
What do you meen by hesitation at the top of the gears? It falls flat wide open at high RPMs or when going from 1/2 to full throttle at higher RPMs?
Old Nov 26, 2003 | 11:21 PM
duckdiaz's Avatar
I’ve always herd better to run rich then lean…
Old Nov 27, 2003 | 12:03 AM
snysny's Avatar
For instance when i go flat out in second gear and then let off and get back on it feels like its flooding
Old Nov 27, 2003 | 12:13 AM
XxDumontRaptorxX's Avatar
What possition on the needle is the clip, if it has good low end, but crappy high end power because its rich, you need to adjust the needle
BTW sounds like you need to raise the needle up a clip or 2, and change the jet size as needed. So the needle sits lower and leans it out a bit
Old Nov 27, 2003 | 07:59 AM
ClutchOlds's Avatar
Sounds like the clip position needs to move. Had the same problem. Clip position helped a bunch. Move it up.
Old Nov 27, 2003 | 11:20 AM
snysny's Avatar
how many nocthes do i move it up. and do i still need to rejet
