So how are they ?
Old Dec 7, 2003 | 12:05 AM
TrailBlazerguy250's Avatar
Default So how are they ?
How are Kodiaks ? Reialble ? Power ? Handling ?
Old Dec 7, 2003 | 12:09 AM
Good for Plowing ? Hunting ? Its a 2x4 Kodiak 400 04
Old Dec 7, 2003 | 11:47 AM
come on somes got to know
Old Dec 7, 2003 | 01:03 PM
Spanxkx's Avatar
they are very good quads...
MSRP: $4,599.00
Engine Type: 401cc, 4-Stroke Single, Liquid Cooled w/ Fan, SOHC
Bore and Stroke: 84.5mm x 71.5mm
Compression Ratio: 10.5:1
Carburetion: Mikuni 33mm BSR
Transmission: Yamaha Ultramatic™ V-Belt with engine braking / Forward,Neut.,Rev.
Starting System: Electric w/ Auxiliary Pull
Drive Train: 2WD; Shaft
Front Suspension: Independent Double Wishbone, 6.3” w/ 5-way Preload Adjustment
Rear Suspension: Swing Arm, 7.1” w/ 5-way Preload Adjustment
Front Brakes: Dual Hydraulic Discs
Rear Brake: Fully Sealed Drum
Front Tire: AT25 x 8-12
Rear Tire: AT25 x 10-12
L x W x H: 78.1 in. x 42.7 in. x 44.1 in.
Wheelbase: 48.5 inches
Seat Height: 32.6 inches
Dry Weight: 547 pounds
Ground Clearance: 9.7 inches
Fuel Capacity: 4.0 gallons
Rack Capacity: 88 Lbs.Fr. / 176 Lbs.Rr.
Towing Capacity: 1,102 Lbs.
Instrumentation: Speedometer / Odometer & Fuel Gauge
Dc Outlet: Standard
Lighting: Dual 30W Multi-reflector Headlights & 21/5W Brake light
Colors: Hunter Green, Beige, Red, '
I would look into a 4x4 kodiak tho if your going to be plowing. but if you compare these specs with any other quad in its class, this quad will be better in almost every way. very reliable, plenty of power! Test drive one, you'll love it! the seats are extremely comfy too IMO!
luke
Old Dec 7, 2003 | 01:17 PM
ISmoKeUonMY350's Avatar
they are a very good and reliable quad i have a 95 kodiak and its stock and im very happy with it everytime ive gone huntin ive been pleased with it they have a good amount of power to for there heavy size
Old Dec 7, 2003 | 01:21 PM
Well Iam going in a hour or two to look at them. I hope their not closed
