12 tooth sprocket on Warrior
Old Dec 10, 2003 | 09:21 PM
DFWATSON's Avatar
Default 12 tooth sprocket on Warrior
I am running a 12 tooth sprocket on my Warrior with 22" Kenda bearclaws for the snow and mud. I am going to run 20" Dunlops for dry conditions. Should I switch to the 13 tooth for the 20" tires? It came with a 12 tooth on it when I got it.
Old Dec 10, 2003 | 09:25 PM
trailride's Avatar
Id go back to the 13 .
Old Dec 10, 2003 | 09:45 PM
chrisz250's Avatar
sry guys.... what does it mean by that??/
Old Dec 10, 2003 | 09:47 PM
trailride's Avatar
By what chrisz250 ?
Old Dec 10, 2003 | 09:48 PM
chrisz250's Avatar
the sproket stuff.....
Old Dec 10, 2003 | 09:52 PM
DFWATSON's Avatar
The Warrior comes stock with a 13 tooth. The 12 tooth is for more low end or larger tires. I have not run the 20's yet and I was wondering if the 12 tooth was too low of a gear to run with smaller tires. I have never had a 13 tooth, this is why I am asking.
yaaaaaa's Avatar
the sprocket he is talking about is the drive sprocket on the clutch, the one right next to your leg up on the motor. I beleive he said it was a 12, the smaller the front tooth the fastser you go but less low end power you will have, and if he would go to a 13 wich i would do for the snow he will get more revs on the bottom end but will loose top speed. Now if he went to a small sprocket on the rear he will go faster but if he goes with a bigger rear sprocket more low end power. hope this helps.
Old Dec 10, 2003 | 09:57 PM
chrisz250's Avatar
thanks for explainin guys
Old Apr 3, 2004 | 02:32 AM
Wickedclownz's Avatar
Think ya got it wrong there man its "The smaller the front sprocket equals more torque but you will lose you top end speed about 5 mph per tooth (on front) The bigger the more top end you will have but you will lose in the Torque department" I hope to get a 12 tooth for my warrior soon how much they set you guys back for a good one? like 15 or so American?
Old Apr 3, 2004 | 08:31 AM
themadwarriorrider's Avatar
No, I'm running the original sprocket on twenty inch hole shot tires on the rear for all conditions. You will be supprised how well it pulls. I don't think you need to change the sprocket or youll lose top end
04 warrior lots of mods
