Stock jetting for a 95 wolverine ?????????
Old Dec 14, 2003 | 12:53 PM
Raptor010101's Avatar
Default Stock jetting for a 95 wolverine ?????????
Anyone know the following for a 95 wolverine
1. Stock Main??
2 Stock pilot ???
3 Stock clip position??
4 Turns for air screw ???
The baffle is missing on the exhaust would that change the jetting at all??
Thanks
Old Dec 15, 2003 | 09:27 AM
95wolv's Avatar
Did you get my PM? in your PM to me, you didn't mention the baffle missing, that will make a difference, takes a lot of restriction out, you may need to go up on the main. Every motor will be different on the mix screw, a good start point is 2 - 2.5 turns from seated, then warm it up and run around, run up to speed in 2nd or 3rd gear, and let it coast, if it pops out the exhaust, it needs to have the mix screw turned out a 1/4 turn at a time unitl it stops. if you get to 4 turns, you may need a bigger pilot. If you don't get a pop or back fire, you should be fine. Good luck, let me know how it all comes out.
Old Dec 17, 2003 | 04:01 PM
SpDdEmOn's Avatar
1. 135
2. 42
3. 3rd notch down
4. I believe its 2 turns out. Anywhere between 2 and 2.5 you should be ok.
I ran stock settings with the baffle out and it was ok.
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Bigtwin700
Sep 9, 2015 09:32 AM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
