banshee jetting. is this in the ballpark
Old Dec 30, 2003 | 08:54 PM
roosthrower's Avatar
Default banshee jetting. is this in the ballpark
After doing several drag races with my step dad's stock banshee I knew that there was something wrong with my banshee. A piped banshee shouldn't be running right with a stock banshee. I took the carbs apart and found that the main jets were 360. Way to large for just pipes, k@n and no air box lid. So can anyone tell me if this jetting sounds good for my mods.
30 pilot
4th clip on the needle
290 mains
and 1.5 turns on the air screws
thanks.
Old Dec 30, 2003 | 09:49 PM
Hozed's Avatar
my buddys has SST's, V-force 2's, boost bottle, k&n clamp on's and i think he is running 280's with the needle in stock position. and his runs good.
Old Dec 30, 2003 | 11:40 PM
thanks
Old Dec 31, 2003 | 12:34 AM
LOWBOWTIE's Avatar
Mine with T-5's, proflow and no lid is 300 mains. (Tad rich)
Old Dec 31, 2003 | 07:13 AM
warrior68man's Avatar
Pure Polaris Predator Hat (when worn backwards it decreases air resistance and cuts seconds off the 1/4 mile...)
lmao that was just funny..I like it! lol
Old Dec 31, 2003 | 09:29 AM
machwon's Avatar
With FMF SSt's I jetted a buddies at 25 pilot, 1.5 turns, aftermarket pipe needle in middle notch, 280 mains with no air box lid. I run the same jetting for T-5's. If its 70-80 degrees you could probably run a size or two lower on the mains. Run the air box lid less than 40 degrees with 280 mains.
Kaleb_00
Jun 1, 2016 09:15 AM
greek271
Aug 8, 2015 08:16 PM
JohnnySplat
Aug 6, 2015 12:07 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
