Using Banshee Parts on Blasters
Old Dec 31, 2003 | 04:20 AM
jrobertson's Avatar
Default Using Banshee Parts on Blasters
I was wanting to get a Dura Blue axle "+4", and came across a site that the 4" axle for the blaster is the same size as a stock banshee axle. Could I just not pick up a Banshee Axle off of ebay instead of shelling out for the dura blue one?
Old Dec 31, 2003 | 07:55 PM
crispy's Avatar
yup
Old Dec 31, 2003 | 08:01 PM
jrobertson's Avatar
crispy, am i going to have to do any modifications to the new axle other then longer chain, and brake lines? In other words, is it an easy fit? Thanks so much
John
Old Dec 31, 2003 | 08:10 PM
crispy's Avatar
You shouldnt have to change anything like your chain or brake lines with a wider axle. now if you wanted a longer swingarm then yes. I think you can slap it right on but let me double check for you, I'll get back with you
Old Dec 31, 2003 | 08:11 PM
jrobertson's Avatar
crispy im sorry i forgot to mention i have a 3" ext. swingarm, its not put on, but im just trying to get everything worked out...do you know off the top of your head how much longer the shee axle is then the blaster?
Old Jan 1, 2004 | 03:05 PM
crispy's Avatar
If you have the stock mechaincal brake (02 and older) than you have to make some kind of a spacer plate to move the brake over a little...but if you have a 03-04 then you will have no prob.. and u have an 03.
um, it may be a good idea to grease the bearings when you put in the new axle. other than that, it should slide right in w/no prob. so overall, it just slides right in. now with the longer swingarm u have to have to make some things longer like lines and chain, i don't know the length of a shee arm but you could probably go to the yamaha website and look at the specs of a shee and figure it out.
Cole Hadden
Jun 15, 2025 09:05 AM
JohnnySplat
Aug 6, 2015 12:07 PM
drewy2dope
Ask the Editor
11
Jul 31, 2015 09:36 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
