still a little lean up top
Old Dec 31, 2003 | 07:48 PM
roosthrower's Avatar
Default still a little lean up top
my banshee is lean on the top end. I am running fmf pipes with 280 mains, needle in the stock posistion, and pilot jet is at stock settings. should I move the needle up a clip or run 290 mains? I ride at sea level and the humidity is pretty high (70+) percent. thanks.
Old Dec 31, 2003 | 08:26 PM
Hiram's Avatar
If the mid-range is fine then leave it alone and go up in the mains, but it doesn't hurt to test what it does with the needle in a different position sometimes you'll be surprised. I have my needle one notch leaner than factory(due to porting reed cages) and what a difference it made, and running 330 mains and it has incredible power and snap everywhere. The power band comes on just above 1/4 throttle.
Old Dec 31, 2003 | 09:28 PM
thanks the midrange seems to be fine so I guess I will go up to 290's or 300's. By the way i'm running a k@n clamp on with outerwear and no lid.
Old Jan 1, 2004 | 12:20 PM
Hiram's Avatar
I have stock airfilter without the snorkle on the lid and 1" cut off the back off the lid. I will soon be running without the lid as soon I get the pro-flow adapter kit in.
Dammar
Apr 20, 2016 06:03 AM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
bvolks
Sep 13, 2015 12:57 PM
Minimod
Sep 10, 2015 09:20 PM
