raptor piston
Old Jan 8, 2004 | 03:05 AM
69camino69's Avatar
Default raptor piston
have an o3 raptor, have installed a white bros pipe, um aluminun open airbox and dynojet kit, was wondering if a higher conpression piston would show any noticeable difference in low and midrange power to make it worth doing, if so is there any carb. adjustments to be made, as you can tell i am new at this, any help would be much appreciated, thank you
Old Jan 8, 2004 | 05:25 AM
14mins's Avatar
69- I would drop in a 11-1 or 12-1 JE piston or a Ross piston. Might as well drop in a stage 1 cam while you are at it. It will be a whole new quad. Those 3 items (piston, cam and HP headgasket) will set you back about 335 dollars.
Old Jan 8, 2004 | 09:34 AM
UBETRUN's Avatar
He's right, a new quad. Tons more low end with a higher compression piston.
Old Jan 8, 2004 | 11:37 AM
CaptBags's Avatar
Are there any downsides to the higher comp piston like harder on engine or, excessive wear? What gas do you run w/ each level of compression. For example: do you run 93 octane w/ 11:1 and, 100 octane w/ 12:1 ect?
What is the stock piston Compression?
Old Jan 8, 2004 | 11:50 AM
trisrik's Avatar
just had 11:1, stage one cam and full white bros. exhaust done. whole diffrent ride really strong down low. don't know about top end still breaking in. seems to run better on 94 than 100.
Old Jan 8, 2004 | 12:16 PM
CaptBags's Avatar
one other thing, i think i've read that the the Stage 1 is for lowend and, Stage 2 cam is more for high end and, that the 11:1 piston brings up lowend as well. So, instead of a Stage 1 cam and, high comp piston both bringing up the lowend, would it be better to go w/ a Stage 2 and, a 11:1 piston and, bring up all around performance?
Old Jan 8, 2004 | 12:35 PM
DuneMe's Avatar
You'll need different valve springs for the stage 2 cam.
Stage 1 cam and high compression piston = great bang for the buck!
Just decide now if that is all you are ever going to want to do. If you think you will want more power just do it all at once or you will just end up buying the same things over and over again.
Old Jan 8, 2004 | 12:49 PM
BigScary's Avatar
I would totaly bypass the stage one cam........I gained Lots of top end after I switched to the stage two cam........and I still have more low end power than I need...........
trust me........if you think there is any way that you will want to upgrade again.....go ahead and do it now........it is much more cost effective to do it once rather than 2 or 3 times like I did.......
Old Jan 9, 2004 | 12:42 PM
ccgrady's Avatar
i agree with bigscary go with the stage 2
Old Jan 12, 2004 | 12:33 AM
CaptBags's Avatar
If I go stage 2 cam, new springs, and, 11:1 piston am i going to need a valve job and, porting?
What else exactly will I need?
