If anybody has the Zip-Ty fuel mix screw on their YFZ please respond.
Old Jan 18, 2004 | 10:07 PM
ridnwarrior's Avatar
Default If anybody has the Zip-Ty fuel mix screw on their YFZ please respond.
If you have the screw on your YFZ450 please respond. I am thinking about getting one and would like to know if it is better. Also a picture would be great. If you have one please let me know.
Old Jan 18, 2004 | 10:38 PM
MNRAP's Avatar
I have one and wouldn't be without it. If you ever plan on adjusting that ingredient in your fuel metering system you MUST have one.
Twisting the carb to move the screw a 1/4 turn is down right rediculos.
Old Jan 18, 2004 | 11:46 PM
Where abouts is the screw located that you have to twist the carb to turn the screw?
Old Jan 18, 2004 | 11:49 PM
MNRAP's Avatar
it is inset into the bottom of the float bowl. you will easily see it if you ever do any jetting changes.
Old Jan 18, 2004 | 11:58 PM
BigScary's Avatar
will that fit on my dual fcr 35's?
Old Jan 19, 2004 | 12:07 AM
So the Zip-Ty hangs down from the bottom of the float bowl? Isn't the starter in the way?
Old Jan 19, 2004 | 12:17 AM
sixsixT's Avatar
I agree, it's a must. The starter is too close to get an adjusting tool in there but a zip-ty will clear.
Old Jan 19, 2004 | 12:24 AM
I'm sold. Sounds like a plan to me.
Old Jan 19, 2004 | 11:29 AM
pudljumpr's Avatar
IF you do any air box mods, that zip screw is a must. Other wise you have to loosen the bolts on the boots, and twist the carb a 1/4 turn to get a screwdriver in there. With the zip ty, you can leave the machine running, stick your finger in and adjust, and have your low adjustments made in about 10 seconds as opposed to 10 min.!!
Old Jan 20, 2004 | 07:32 AM
135boom's Avatar
I got one, made fine tuning much much easier!!
