Warrior Oil cooler
I don't have any solid data, but past threads indicate it is a good idea to add it to any Warrior, and a must for modified ones which naturally run hotter. I have my site viewable (still under construction though). If you want to see my oil cooler setup, check out my site!
Hey Colby did you use just the oil filter cap or the whole housing? If you go to the site on the other post it has alll of the parts that used, so I was wondering if that was the same way you did yours. Thanks
I used the housing and cap (you need both). I also used the Big Bear hoses, then cut off the ends and spliced in some lines I got at a tractor store. Cheaper alternative to having custom lines made.
