Raptor mini-rail
Old Jan 21, 2004 | 07:20 PM
westtexasbaja's Avatar
Default Raptor mini-rail
Just recently bought an 01 raptor for $1500 and I plan to use the motor, etc. in a mini-rail (ATK - all terrain kart) like the attached pic. What motor upgrades would be recommended? I plan to at least upgrade trans to 02. What other options are available for trans upgrade beside an 02 trans? ATK's weigh around 750-850 lbs dry.
Thanks for any info,
G.
all terrain kart
Old Jan 21, 2004 | 08:03 PM
caliraptor's Avatar
That thing would weight abit more than 1,000# wet with a driver. I would get a high comp piston(12:1), cam(stage 2) and a good exhaust. That would get that thing moving.
Old Jan 21, 2004 | 08:52 PM
Outlawlawndragster's Avatar
Nice rail ! Hey Nothing agaist raptors I own one But if it were me I would buy a 2 cyl sled motor at least a 700 like a polaris rmk for example and run the CVT trnasmision off the sled huge power range and Power to weight ratio is High a good 700 cc twin can produce 110 HP with out much work and then HANG ON
Old Jan 21, 2004 | 09:50 PM
Cali: what would be a good sprocket combo to start with?
Thanks Outlaw. A lot of people are using the setup you described. I've driven both a cvt and shifter and I prefer shifting. Thats why I am using an atv motor versus a sled. Don't get me wrong, twice the horsies would be nice, but there's nothing like the feeling of shifting.
G.
Old Jan 21, 2004 | 10:54 PM
caliraptor's Avatar
I would go with a 12/40 or even a 12/41-42...that thing will be heavy and I dont think you will be going FAST, this gearing will prpbably put you in the 65-70mph range, with 21in tires. If you go with even bigger tires you would have to make more changes.
Old Jan 21, 2004 | 11:01 PM
JohnnySplat's Avatar
i doubt it would pull 65-70 without some significant mods. A stock rappy can only pull mid 70's, and if you factor in the extra weight and lower gearing i really doubt it'll be going 65-70, maybe 55-60.
Old Feb 4, 2004 | 06:02 PM
Who is a good source for quality aftermarket engine parts? aftermarket clutch and trans?
Thanks,
G.
Old Feb 4, 2004 | 06:56 PM
caliraptor's Avatar
I think craycraft has GYT-R clutches, but Im not sure who you would have to go to to get an 02 trans
Old Feb 5, 2004 | 12:31 AM
cdrracingguy's Avatar
go to alba's web site and click the raptor and then motor mods..
they have an 01 to 02 tranny kit with all the fixins.
Old Feb 5, 2004 | 01:08 AM
cidnitro's Avatar
What about a yzf600, more power and revs, and lots of gears. what more could you ask for?
they hold up great in minisprints.
