black wheels
Old Jan 22, 2004 | 04:42 PM
rede34m5's Avatar
Default black wheels
does anyone know what companies make black aluminum wheels or black wheels at all. i saw some on some alba quad on their site. they said they were douglas but they aren't on douglas's website.
Old Jan 22, 2004 | 05:03 PM
Raptorboy4life's Avatar
ITP makes the black rims umm there called delta wheels if that helps!! Also does anyone know where to find the best tire-wheel packages??
Old Jan 22, 2004 | 05:06 PM
rede34m5's Avatar
www.rockymountainatv.com for the best packages
Old Jan 22, 2004 | 05:12 PM
thanks waht does ply mean? also what size tire should i get for a yamaha raptor?
Old Jan 22, 2004 | 05:20 PM
rede34m5's Avatar
i think ply refers to how many layers of rubber there is. what size rim or tire size do you have?
Old Jan 22, 2004 | 05:29 PM
JohnnySplat's Avatar
ply is the number of layers of rubber. the higher the ply rating, the longer the tire will last. most atv tires range from 2 ply to 6 ply.
Old Jan 22, 2004 | 06:43 PM
HiFlyinRaptorRyder's Avatar
If you just want black rims have your stockers powercoated. You can get all four done for under $100 and it makes them 10x stronger than before.
Old Jan 22, 2004 | 06:48 PM
Roach007's Avatar
I was thinking of having my stock Raptor wheels powercoated black, would that work on aluminum wheels.
Old Jan 22, 2004 | 06:56 PM
Yamaha660R's Avatar
You could have them powdercoated black and it would be ok.
Tire sizes on the Raptor are 21X7X10 on the front.
20X10X9 on the Back.
2ply is the thinest tires, 4 ply is good for dunes and mild racing, and 6 ply are thick for rough or rocky trails.
Old Jan 22, 2004 | 07:06 PM
rldbobcat's Avatar
The rims on the Alba bike might be carbon fiber rims also, im not sure i have not looked at it. If you want yours black I would deff. have them powdercoated, if you paint them you will be touching them up often. Paint does not stick to alum. well at all. With powdercoated wheels you will prob never have to worry about them again. Also the ply rating on the tires is the number of layers of rubber on the tire carcass, it does not include the tread so they wont necessarly last longer. What the ply affects mainly is the sidewall strength and the load the tire can also handle. With a heavy ply rating the tires do not squat nearly as bad and are also harder to puncture. And usually because of the more plys the tire has the weight of the tire is usually greater also due to the more layers of rubber there is to the tire. What type of riding do you do? The type of riding you do will depend on the tire you want.
