raptor decompression??
Old Jan 22, 2004 | 09:32 PM
rudyraptor's Avatar
Default raptor decompression??
tring to get bike running. just wanted to make sure when you spread the weights open the the pin goes in. Looks like tahts the only way it could go but making sure. I puled my plunger out again and the hole in it was plugged with yamabond, dont ask me how but it was so hopefully that was the problem.
Rudy
Old Jan 22, 2004 | 10:49 PM
tmouse's Avatar
Good luck with puting your cam back in I took all the decompression system weights,pins,and springs off there just more parts that can tear up your motor u really only need them if yourre going to run a high compression motor.
Old Jan 22, 2004 | 11:06 PM
UBETRUN's Avatar
NOT TRUE, you need those parts. It puts a lot more strain on your starter without the decompression mechanism. With a high compression motor, it just won't start.
I read your post earlier and wanted to respond but my short term memory is failing, I can't remember exactly when the pin retracts. There really is only one way to put it together. If you can open the weights with your fingers and they snap back without binding, it sounds right.
Old Jan 23, 2004 | 07:58 AM
Ward660R's Avatar
Your right Rudy.
The motor spinning fast throws the weights out and pulls the pin in. When the motor is at crancking rpms it should not be fast enough to throw the weights out.
Old Jan 23, 2004 | 08:09 PM
rudyraptor's Avatar
thanks everyone but i found the problem. It was like i said the yamabond plugging the hole up in the rod that goes in the cam. Now the only problem i have is that i believe i fried my relay tring to start it before. I even bought a new battery. I could not see it starting without the decompression. Mine would only turn over once then dead battery. I do have high compression too though.
rudy
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
