Axle Question???
Old Feb 1, 2004 | 03:16 PM
Foxracin's Avatar
Default Axle Question???
Whenever I ride my raptor at slow speeds the rear axle makes a squeaking noise and whenever I speed up it stops. Does this mean I need to replace my bearings or what?
Thanks in advance!!!
Old Feb 1, 2004 | 04:04 PM
Raptor149's Avatar
Are you sure it's the axle? Swingarm pivot bearings will squeak when the go bad too. I also find that when I don't spray my rear shock with WD, it squeaks sometimes when I first sit on it. Maybe you're pads are sticking your rotor. If you can't narrow the sound down to anything else, then that's a good possibility. Especially if it's an 02 model. I redid my Feb. 02's axle bearings last summer, and man, the old ones were pretty much shot.
Old Feb 1, 2004 | 10:44 PM
Stillander's Avatar
my 04 warrior does the same thing, it squeeks when i go slow, but when i use the back break it stops, i figure its just my brake pads
Old Feb 2, 2004 | 01:42 PM
Shav0's Avatar
check out the rear chock mount under the seat. mine squeaks when it gets dry and dusty. It is just because of the bushings and the rubber un against the other parts.
cornermike
Sep 10, 2015 08:30 AM
John Reed
Sep 9, 2015 03:46 AM
bmark0610
Sep 7, 2015 09:42 PM
MooseHenden
Sep 6, 2015 04:24 PM
snowolson
Aug 31, 2015 03:51 PM
