Modified BlasterR V/s Stock 400ex
I have a 01 blaster with toomey b1 pipe, dynojet kit's, v-force delta2, porting, 20mm piston wiseco bored, k&n Filter, Barnett Clutch, 30mm Carbu and Spacer and my friend have a 03 stock 400ex and i always smoke him, is that normal???
With those mods on that blaster you would be pumping out at least as much if not more than a stock ex. I know this because I have a blaster with a built engine and I know it makes a ton of power for being a 200cc, at least enough to be a stock ex.
with pipes, porting, and a larger carb, I believe it 100%. Your power to weight ratio is much better than a stock 400ex.
"porting" is a very general word. There is top end porting, mid range porting, bottom end porting, and everything inbetween. Even idiotsshouldnttouchagrinder porting, and ripyouoffonlytouchexhaustport porting.
