What cam would you use.
Old Feb 25, 2004 | 08:47 PM
XxDumontRaptorxX's Avatar
Default What cam would you use.
I like my webcam. it has alot of topend.
Old Feb 26, 2004 | 12:05 AM
Mr45auto's Avatar
Originally posted by: BigBubba
Mr45Auto: I can't quite make out what that dyno sheet says, is the upper line your HP or the bottom (I assume bottom cause it's hard to pump out 90 HP ;-) ) Also, where did you get that dyno done? I did my at DTR in Salem and wish I could of found another place. We should hook up and ride sometime!
If you have a tft screen it's hard to read, a crt is easier. It's actually 58HP with 47 ft lbs torque. I did mine at LRD in Tualatin. I'd be up for a Sand Lake run shortly, my pipe is being repaired again and I gotta install a Hinson basket..... then the ride is on...
Old Feb 27, 2004 | 10:33 PM
RaptorForever's Avatar
What cams are better HiRev?
Old Feb 27, 2004 | 11:42 PM
Ugintel's Avatar
what did you guys pay for cams? i got a stage 2 hot cam for 100 + 12 for shipping, and NO core deposit
Old Feb 28, 2004 | 12:23 AM
  #15
where did you get that?
Old Feb 28, 2004 | 12:29 AM
  #16
Raptorboy4life's Avatar
Whats the core charge and where (what sites) can i see cams for sale on???
Old Feb 28, 2004 | 10:52 AM
  #17
Ugintel's Avatar
from a guy offa ebay, it was NIB.... a core charge is where they have you send them your old cam
Old Feb 28, 2004 | 02:28 PM
  #18
Yamaha660R's Avatar
www.magnoliatractorinc.com
There you can buy the stage 2 cam/valve springs as a set.
Old Feb 28, 2004 | 04:39 PM
  #19
How much HP could be expected from a 686 12:1 comp, Stage 2 Hot Cam, CT Pipe?
Old Feb 28, 2004 | 07:11 PM
  #20
Yamaha660R's Avatar
With the perfect jetting and tuning, 60+ hp is possible.
