Raptor won't move
Old Feb 28, 2004 | 04:34 PM
freshbait's Avatar
Default Raptor won't move
I was out back on the track recently with my 01 raptor when I stopped then went to take off and it seemed sluggish and bogged down, I figgured it was the mud, stopped backed up took another run at it same thing, It smelled almost like a burnt clutch with alittle smoke comming up from engine, again I figured it was just the water and mud. Then I went to take off and it bogged down and then reved up. I don't remember hearing anything snap and there is no grinding noises. I loaded it into the tractor and took it to the shed, cleaned it up. When I pull the clutch in and shift the rear tires "click in and move" like normal shifting into gear when stopped. However When I release the clutch she just sits there and and doesn't move, Again there are no grinding noises or anything like that, If it was the clutch wouldn't it be locked in gear?? Or is it the tranny, I haven't beatn' the quad just normal riding around in the pit, and track out back. The local shop wants $450 TO JUST LOOK AT IT!!!!! I haven't split the cases yet, and if I knew what the problem was or was pointed in the right direction I could fix it in my own garage. Anyone have any ideas?????? Or is it the TRANNY DEMON?????
Thanks
Old Feb 28, 2004 | 04:56 PM
RoostItUp's Avatar
If 2nd gear moves then it's prolly a burnt out clutch.
Old Feb 28, 2004 | 08:38 PM
freshbait's Avatar
2nd gr won't move either
Old Feb 28, 2004 | 08:43 PM
sixsixT's Avatar
Sounds like the clutch.
Old Feb 28, 2004 | 09:06 PM
YamRaptor's Avatar
I agree with the guys on this. The same thing happened to my bike before and it was the clutch.
Old Feb 28, 2004 | 10:08 PM
RedNeckMXRider2's Avatar
check the clutch cable it might be binding up like my motion pro did i got out ran by a 400ex with just a FMF pipe cuase of it and DONT GET A MOTION PRO THEY SUCK!
Old Feb 28, 2004 | 10:32 PM
freshbait's Avatar
clutch cable not binding up, I'm splitting the cases on monday when I get out of work, anything I should look out for??? I'm putting in a hinson clutch basket w/ the new clutch and springs, Hopefully its just the clutch,
bmxatv10
Oct 14, 2022 06:23 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
