YZ 250 engine in blaster?!
Old Feb 29, 2004 | 10:14 AM
blaster2002004's Avatar
Default YZ 250 engine in blaster?!
I was wondering if it is possible to put a YZ 250 dirtbike engine in a blaster frame? What would you need to do and what would be a list of parts. And a price estamation for all of it done not including labor.
Thanks
Old Feb 29, 2004 | 11:46 AM
Criminalpoet's Avatar
Ive seen it done and unless you want to vibrate right off the bike dont do it lol. Hella fast but the vibration makes for a lot of discomfort. Plus youll need a swing arm so long to keep the power on the ground that the only thing your bike will be good for is going in a straight line.
Old Feb 29, 2004 | 12:49 PM
What do you mean is it gonna be to powerful for the size? What if i got a good set of front and rear suspension, and extended a arms and swingarm?......and would the engine even fit in the frame including the radiator. i can buy a 2001 yz 250 engine for 200 bucks with everything carberauter, cooling system, etc. If i did would it actually be worth the effort to race it?
Old Feb 29, 2004 | 06:36 PM
wanaply21's Avatar
iv raced one and it had to spot me like 2 lights but i still beat it but yes it can be done but i dont kno how much it will cost
Old Feb 29, 2004 | 07:31 PM
04RaptorLE's Avatar
I have a 97 blaster with an 89 YZ 250 motor in it.The vibration is not as bad as you would think.I do have a Laeger swing arm and the quad is 3 inches wider than stock. Durable axle that fits a Suzuki and 1 1/2 inch spacers up front.It is fun and definately fast..Good luck
Old Feb 29, 2004 | 07:34 PM
crispy's Avatar
You will need to weld some coustom motor mounts to the frame, and the motor needs to be inline with the rear axle. If you know someone good with metal, it's very easy. but the new swingarm will run you at least 300$ minimum. You can get extenders for about 100 thought, but they don't offer the length. I would go atleast 4inches longer or it's going to be comin up all the time and it really wont be to fun.
Old Feb 29, 2004 | 07:46 PM
04RaptorLE's Avatar
The only motor mount you will have to modify is the upper mount. This is my experience with the motor I used. I had to cut it and widen it. You will also have to get a radiator and mount it.
Old Feb 29, 2004 | 09:59 PM
my piston just seized up in my blaster today so I think im closer to putting a yz 250 engine in it.
Old Feb 29, 2004 | 10:17 PM
How much would all that cost and what exactly will you need to mod or change? And how did you get the radiator's in there? It seems like the frame would be to small. My friends dad is really good with engine in fourwheelers he put a yz 450f engine in a 300EX frame, and he said if i had the parts he would put it together. What is the top speed with that engine in it? and the pipe and silencor will actually fit in it with out cutting into the frame. AND the biggest question of all is will it actually be faster and better with that engine in it?!
Thankyou
Old Feb 29, 2004 | 10:27 PM
Eceriderjbomb's Avatar
Tell me if you do it this would be sick... try to get some videos in here to to show its power
