Oil injector
Old Mar 1, 2004 | 04:54 PM
Shav0's Avatar
Default Oil injector
Because I can't order the kit i guess im going to have to make one myself.
I pretyt much know how to make it except for one thing.
What do you use to fill the hole where the line attached into the carburator. Also, what can i use to fill the holes where the lines passed into the pump through the case?
any help would be great.
Thanks
Old Mar 1, 2004 | 05:27 PM
hondaguy2's Avatar
Caulk or Silicone either one will work. I think.
Old Mar 1, 2004 | 07:22 PM
Shav0's Avatar
do i have to drain the gas that is already in the carb when i do this?
Old Mar 1, 2004 | 10:56 PM
Spoony's Avatar
I don't think that you have to drain your gas. When I got the kit, I already had my carb out. As for the carb, the kit gives you a plug that you put over the hole. If you don't put it on, your motor will sieze, so make sure the plug you get is a tight fit.
Old Mar 2, 2004 | 10:47 AM
Shav0's Avatar
thats the problem, im not getting the kit so therefore i dont have the plug. Im trying to find somthing else that will fit and stay tight. any ideas?
Old Mar 2, 2004 | 12:30 PM
Spoony's Avatar
If is steel, you can weld it shut, or if its brass you could solder it. These could work. Also, your local hardware store should sell plugs. Just bring your carb with, and look for one. You could put silicone around it to make sure that it is a tight fit. As for the space where the two hoses go through the case to the pump, you can epoxy a piece of metal inside, and the put the cover on the motor, and caulk it.
craacker
Sep 9, 2015 04:32 AM
Rob4092
Sep 11, 2006 09:53 PM
Thor
Jul 19, 2002 05:00 AM
yamahagye
Jan 26, 2002 03:32 AM
Rob4092
Apr 28, 2000 12:59 AM
