warrior question???
Old Mar 1, 2004 | 07:46 PM
BornToRide101's Avatar
Default warrior question???
This summer I am totally ripping apart my warrior and clean every thing when it’s apart I am painting the frame and changing the bearings and brakes, what else should I do and what parts should get changed every few years (it’s a 2000 and I don’t think it has ever hade any major work done 2 it)
Old Mar 1, 2004 | 09:18 PM
dose aney 1 no of aney thing i should check or replace?
Old Mar 1, 2004 | 09:42 PM
AngryHampster's Avatar
oil filter.
if you're taking apart the engine new rings wouldnt be a bad idea.
Old Mar 1, 2004 | 10:00 PM
TRLYFZ450's Avatar
Just check everythink out. I would grease the shock bushings,check the stearing stem bearing, Grease all the pivot pionts. check out the a arm bushings. Check out the wiring harness for damage. There is lots you can do.
wendal
May 9, 2024 09:29 PM
bigred20653
Oct 2, 2015 10:05 AM
Ridgebackguy86
Sep 19, 2015 12:48 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
