raptor keys
Old Mar 2, 2004 | 10:30 AM
Baiter's Avatar
Default raptor keys
i want to know if i can by pass the ignition key and just use a thether or do i still need the key? inm puting after market bars on and dont want to make to many holes in the plastics. any help would be great
Old Mar 2, 2004 | 10:54 AM
Baiter's Avatar
Default raptor keys
some one has to know
Old Mar 2, 2004 | 11:55 AM
Shav0's Avatar
Default raptor keys
im not to sure on a raptor, but on a blaster and a banshee you can just unplug the switch and it should fire right up,
try it, if it dosnt work theb just put it back together.
Old Mar 2, 2004 | 11:59 AM
Turbo33's Avatar
Default raptor keys
yes you can. Take the two wires that goes to your switch and connect them together. When you install your tether it goes to your coil. You will put one wire on one side of the coil ground (bolt in frame) and the other wire connects to the wires that feed the coil. What happens is when the cord is pulled it grounds out the coil.
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 11, 2015 11:42 PM
1ArmBandit
Sep 8, 2015 08:59 PM
black_thunder
Sep 7, 2015 01:24 AM
byronman
Sep 6, 2015 06:34 PM
