Oil filter location on 94 Kodiak??
Old Mar 2, 2004 | 03:14 PM
Snug's Avatar
Default Oil filter location on 94 Kodiak??
I just bought this machine and gave it a good cleaning, and fresh fluids. I drained the oil, but where is the filter located?
What type of tranny fluid should be used? It's a 400 5spd.
Thanks
Doug
Old Mar 2, 2004 | 09:53 PM
KNOWSALOT's Avatar
The Facility
Follow the oil lines oming from the oil cooler. They both run into a small housing held onto the engine with 3 allen head bolts.
Remove these bolts and the cover and the oil filter will be revealed.
The housing uses an o-ring seal so don't worry about needing a gasket.
As for transmission oil,......this engine uses the same oil bath for both the transmission and the engine. Oil capacity is right at 2 1/2 Qts.
Use a 10W40 or 20W50 motorcycle oil......Honda GN4, Yamalube, Castrol ATV Oil, etc.
Old Mar 3, 2004 | 01:18 AM
Snug's Avatar
Thanks for the detailed instructions. Worked like a charm.
Doug
Old Mar 3, 2004 | 01:23 AM
KNOWSALOT's Avatar
The Facility
No problem. Glad I could help out.[img]i/expressions/face-icon-small-happy.gif[/img]
akguy31
Aug 31, 2019 04:34 AM
Steeldon
Sep 9, 2015 09:38 AM
black798
Sep 9, 2015 07:42 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Sep 2, 2015 11:15 PM
