Bruin worrys
Old Mar 2, 2004 | 08:03 PM
stir's Avatar
Default Bruin worrys
I have a bruin, had it now for about 2 months 700km so far, what i have found so far is that the 4x4 light flickers most of the time ,and it is very loud. At about 40km i rev at 5300 rpm 50kn/h is about 6000rpm, is this to much or normal.
Old Mar 2, 2004 | 09:19 PM
nubbin's Avatar
Hi stir, I have a bruin and have no trouble with the 4x4 light flickering. You might have a loose conection. Your still under warranty see your dealer. I would also mention the loud noise. I don't have a tack on mine, so I don't know what rpms I am at, but I don't think that it is unusally loud. I have in the past had manual transmissions and automantics. The automantics have been louder then the manuals, I guess that it has something to do with the belt in the auto's. Maybe someone else on this forum can give you better information then I can. I hope that everything turns out for you.lol
Old Mar 4, 2004 | 10:21 AM
Kodiac400's Avatar
Hello I have a 02 Kodiak and at around those speeds mine seems to rev loud as well. I don't have a tach so I can't tell you exactly my rpm but I'm guessing its around 5000. I still would have it checked just incase. Hate to see you ruin something. They are likely going to tell you that its the nature of the beast.
Old Mar 4, 2004 | 10:22 AM
Kodiac400's Avatar
Ops..............almost forgot welcome to ATV Connection.
Old Mar 18, 2005 | 08:17 PM
Grubes's Avatar
I have an 04 Bruin 350 and when the light flickers, it means it is trying to engage into 4x4 mode but if you slow down, it wont flicker. If you go fast, it makes it hard because the gears are spinning and arent matching up. its like revving up the engine and putting it in gear- it just makes a grinding noise like its trying. Its the same thing. if your turning, it also does it. try not to give it gas or let the tires pull the engine when you engage it in 4x4 mode. Also welcome Stir. Im new here
cboler9
Sep 24, 2015 08:35 PM
Rooky
Sep 9, 2015 03:16 AM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:54 PM
braap123
Sep 7, 2015 12:58 PM
blessedn09
Aug 9, 2015 03:07 AM
