HELP!! Jetting w full SPARKS and K&N (raptor)??
Old Mar 5, 2004 | 05:18 PM
jerstilly's Avatar
Default HELP!! Jetting w full SPARKS and K&N (raptor)??
I am going to be getting my full Sparks X6 exhaust along with a pro flow adapter with a K&N (with outerwear) in a few weeks now. I am just curious what I should run for jetting (mains, pilots, air screw mixture, needle slot) with a GYTR Jet Kit. I ride at anywhere from 400 ft above sea level to 1200 ft above sea level. I will be trimming the snorkel flaps and drilling 2-2" holes in the most rearward side of the air box lid. Thanks alot...
Old Mar 5, 2004 | 05:21 PM
AlphaRaptor660R's Avatar
I'm thinking you should start off somewhere around 160-165...
Old Mar 5, 2004 | 06:20 PM
sixsixT's Avatar
There or 155/160 and 25 pilots 2 1/2 L and 1 3/4 R on the mix screws.
Old Mar 5, 2004 | 06:28 PM
caliraptor's Avatar
hey six, does one mixture screw have to have a bit more out than the other? I have my both screws at 2 1/2 turns out. Which one has to be screwed out more?
Old Mar 5, 2004 | 08:25 PM
RAPTER's Avatar
Make sure your floats are on point if you don't know how then try and learn how to adjust them cause I have the same exact setup except I have a foam filter. I attempted to jet my raptor and I had the correct sizes, turns everything but my floats were out and bike ran like crap so I took it to the dealer and they said the floats were off. I looked at all the post on adjusting the floats but I just couldn't get it and don't have enough patience for trial and error. Now my girl runs STRONG!
Old Mar 6, 2004 | 03:20 PM
jerstilly's Avatar
TTT [img]i/expressions/face-icon-small-smile.gif[/img]
Old Mar 6, 2004 | 03:30 PM
sixsixT's Avatar
You probably don't have to have them set different. Take another look at my last post.
RAPTER is right about the float level.
Old Mar 6, 2004 | 04:13 PM
Yamaha660R's Avatar
Sounds right.
Old Mar 6, 2004 | 04:57 PM
jerstilly's Avatar
What about the needle settings? Where should I go with them? Thanks
Old Mar 7, 2004 | 11:30 AM
jerstilly's Avatar
