need help on Lonestar a arms. broken heim joint
Old Mar 6, 2004 | 03:05 AM
INSeaRChOFDUNez's Avatar
Default need help on Lonestar a arms. broken heim joint
one of the upper heim joints broke of as I was trying to adjust it, it was seized and i was trying to turn it alil a time and my patience was low and i turned it as hard as i could and the joint came off right where the a arms starts. now mos t of the joint tread is in teh a arm and i cant get it out. i tried putting abead of weld on top and then welding a nut and i tried drilling in the middle and using one of those extractor taps. I havent been able to fix it, any help will be appreciated.
Old Mar 6, 2004 | 03:24 AM
LOWBOWTIE's Avatar
If you drill all the way through the center and keep increacing the drill size . Soon there won't be much of the heim bolt left and you may be able to get it out with a punch then.
Old Mar 6, 2004 | 07:41 AM
aussiequadrider's Avatar
then buy a new a-arm
Geoff.
Old Mar 7, 2004 | 03:40 AM
then i took it to a machine shop and had them do it. it came out nice, the crome is is alil blueish but i dont have to buy a new arm now. thanks for the replies
bvolks
Sep 13, 2015 12:57 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
alzgarvin
Sep 11, 2015 08:53 AM
89Lt250r
Sep 7, 2015 07:53 PM
